Enables or disables Online Certificate Status Protocol (OCSP) signer's ocsp-nocheck for SSH2 x509v3 authentication.
| x509v3 | Specifies x509v3 certificate-based authentication. |
| ocsp | Specifies configuring OCSP for real-time certificate revocation status checking. |
| ocsp-nocheck | Specifies the extension id-pkix-ocsp-nocheck. If present in the OCSP signer's certificate, then it is trusted for its lifetime. |
| on | Specifies to override the id-pkix-ocsp-nocheck extension in the OCSP signer's certificate and forces the extension as if it is present. |
| off | Specifies to behave per the extension's presence in the OCSP signer's certificate. If not present and the OCSP signer is not root CA, then the whole OCSP will fail (default). |
| signer | Specifies the OCSP signer that signs the OCSP response. |
Off.
The following example enables OCSP signer's ocsp-nocheck for a SSH2 x509v3 server.
# configure ssh2 x509v3 ocsp signer ocsp-nocheck on
This command was first available in ExtremeXOS 32.2.
